fingerpriting and tracking protection change to disabled after full clearance of browsing data
damdidum
Whenever I delete fully browsing data (all time) and everything, Tracking Protection and Block Fingerprinting become disabled - so I have to manually enable them, and I have to repeat this process everytime i do a compelte delete of browsing data (on Advanced, select 'Delete data')
damdidum
Re: fingerpriting and tracking protection change to disabled after full clearance of browsing data
if possible please fix bug in the next update because it is a bit serious, of course, now i will remember to turn these optinos bck on manually, but it is not a very good buy
damdidum
Hi @catsxp,
I tried an uninsall and re-install of catsxp it did not solve issue.
But this does not happen on my other system that catsxp is installed on (same OS) - however, on the system which it does happen, I tweak casxp more to my liking in the settings - any idea why this may be happening? Are you aware of this issue and are there any troubleshooting steps you can recommend?
上次由 damdidum 在 2024年 10月 20日 23:16,总共编辑 1 次。
damdidum
I can confirm that this behavior occurs if I clear the data for "site and chield settings". If "site and shield settings" is not checked (not deleted/purged) in history, then the tracking protection and finger printing do not turn off/become disabled.
damdidum
Also it seems this is also a bug in brave? https://community.brave.com/t/clear-jus ... ngs/258703
From 2021, that has not been fixed? Is it also a bug in chrome as well?
Or maybe it is not a bug, maybe it is expected behavior, perhaps "Site and Shield settings" should not be cleared...
上次由 damdidum 在 2024年 10月 20日 23:25,总共编辑 1 次。
Wait! Find the reason for positioning
damdidum
This is expected behavior - I thought it is a bug and I was wrong - if you clear sitte and shield setings, fingerprinting and tracking revert to Standard in brave.
But what I do not understand is why in catsxp, it reverts to disabled instead of standard as it does in brave.
See here: https://community.brave.com/t/how-to-av ... red/464690
Anyway, from now on I will 'uncheck' site and shield settings when resetting history. Sorry and best wishes.
