Possibility disable external app popup prompt?
来自: Czech Republic
帖子 redfox »
I tried all approaches to disable the popup warning (prompt), when opening an external application from Catsxp, but with no luck. It seems that Chromium developers removed all previously functional variables, capable of handling this.
In particular, I use Thunderbird for opening mailto links, but Catsxp (Chromium) always displays a popup, and I have to click the button to allow to run Thunderbird to compose the mail. It is quite annoying.
Catsxp developers, please, would it be possible to add an option to disable the popup and allow all external applications by default? There exist(ed) a variable in Chromium "protocol_handler.policy.auto_launch_protocols_from_origins", but it does not do anything.
Thanks in advance.
Re: Possibility disable external app popup prompt?
Trying Super drag !
来自: Czech Republic
帖子 redfox »
Super drag is useless in this case. Mozilla Thunderbird is an external desktop e-mail application, running in the background / system tray.
We need to disable the Catsxp/Chromium security warning/popup when clicking a mailto: link on a webpage...
Is the default email sending program successful in Win?
If the default is successful, it will directly call the default email program for sending!
来自: Czech Republic
帖子 redfox »
Thunderbird is my default mail program in Windows 7.
But, when I click a "mailto:" link on a web page, Catsxp always opens a warning popup, in oder to allow execution of this external application (TB). See the screenshot below. The popup is displayed even if I check the checkbox to remember the site settings.
I would like to allow to open all mailto links on all servers with Thunderbird as my external application, without any popup or warning.
来自: Czech Republic
帖子 redfox »
There is also a web page explaining this further, from another user...
https://support.google.com/chrome/threa ... hing?hl=en
来自: Czech Republic
帖子 redfox »
Any chance to permanently disable the external application warning popup (see above) in a new version of Catsxp?
I know that Chromium developers removed this possibility from the code, but Catsxp could fix it without problems...
