Since v3.9.2 release - web page flickering
The cause is unknown. It could be some ads failed to be blocked or it could be indeed rendering problems. But it's real. I want to report it so you could know that there is a problem like that. I can't give you any videos because it happened randomly and not specific to any websites. This happened since v3.9.2 release. Previous versions didn't have such a problem.
上次由 s6nonqxt9y886fdp 在 2023年 9月 13日 19:24,总共编辑 1 次。
Re: Since v3.9.2 release - web page blickering
If that's the case, then we can only wait for later improvement!
It is possible that there is a compatibility issue between the new kernel and the catsxp code
Re: Since v3.9.2 release - web page flickering
The problem is still there on beta-7.
The problem I'm encountering is different from this problem reported by another user:
https://catsxp.com/forum/viewtopic.php?t=1161
My problem is more about embedded media, e.g: embedded TikTok on forums, animated ads on websites,...
They are causing the flickering. A very quick flicker that only happened once when loading the page.
After the page is fully loaded, they are gone. This happens either when using Catsxp Shields or Ublock Origin.
It seems to have nothing to do with hardware acceleration or the graphics card, as unlike that user, I have never experienced any problems on YouTube.
