bookmarks sidebar layout
casdcoast
帖子 casdcoast »
I noticed in the latest update a change to the bookmarks side layout.
I don't like the layout too much and sometimes it freezes.
Is it possible to make an option so you are able to view them under
the previous view before the update?
I tried all the new options, but none are as good and smooth
like the previous version.
Re: bookmarks sidebar layout
New events always require a process of adaptation
The old version has a single bookmark function and relatively simple operation
In the far right function menu, you can switch to <Compact view>
3.8.1 Forced use cannot be customized
3.8.2 beta-1
catsxp://flags/#power-bookmarks-side-panel
setting Disabled
casdcoast
帖子 casdcoast »
The flags option works great in 3.8.2 beta-1.
