New Mouse Gesture Request
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
I email a lot of articles. It would be nice to have a mouse gesture I could use for "Mailto"", so that I am on a website, I can make my gesture and a "compose email" appears from my default email program.
The website link would be in the body. If possible, the website title could appear in the subject line.
Re: New Mouse Gesture Request
Thank you for your proposal!
Personally, I think it is unreasonable to use gestures to achieve this function
Beta-1 has added a new super drag action: Email selected text
catsxp_user
帖子 catsxp_user »
totally and absolutely agree.
when updating the browser, please do not change any default settings so that any update does not require further re-settings
catsxp 写了: 2023年 1月 15日 09:35 Thank you for your proposal!
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
catsxp 写了: 2023年 1月 15日 09:35 Beta-1 has added a new super drag action: Email selected text
I can not email the tab url,which is what I wanted to do.
If I select the link in the address bar and use super drag (I have already set the super drag motion), it only wants to create a new tab to my session.
I want to be able to simply have some type of gesture to send a tab URL to read or analyze...sorry if my request was not clear enough.
If I select text within the tab I'm in, then it works but every time there is an interim step to "OK" it...too much mouse clicking, etc. I'm trying to save steps. Maybe that's why I thought "a simple mouse gesture and the tab url is sent to my default email with the URL in the body,,,".
So if others need this, great, but this option has too many steps and I can't even get the tab URL...thanks for trying, appreciate it.
Don't expect browsers to support this behaviour natively. The original intention of this action is to provide a way to quickly start the mail program.
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
catsxp 写了: 2023年 1月 17日 04:44 Don't expect browsers to support this behaviour natively. The original intention of this action is to provide a way to quickly start the mail program.
Before using Catsxp, I was using Cent. The author added that feature early on.
If you need to email various tab URL's, as noted, Cent method is the quickest. Gesture on any tab, email program called up (choice of default, gmail), the url is in the body and the subject line is already populated with the tab title. Try it.
Beta-1 will add more information and directly call the WIN mail program
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
It works better and I appreciate the prompt is gone.
How do I just email the tab url? Seems I actually have to select text, perform drag, then email appears but has the unneeded selected text.
That's why I feel a mouse gesture to "sent tab url to email" is cleaner...
but thanks, it works!
