https://github.com/FilipePS/Traduzir-paginas-web
Downloaded TWP_9.7.2_Chromium.crx but when dragging into the browser, it will "download" the file but not installing it. Developer mode turned on. Allow installation and enabling of third-party extensions on Settings/Extensions is also turned on (it's on by default btw). Tried with --enable-easy-off-store-extension-install on StartupParm.txt. None worked.
I guest I have to use Load unpacked?
Need help installing this extension
Re: Need help installing this extension
extensions page
Drag and drop extensions to the page, and it will be installed automatically.
Nope. The download dialog appeared and it will "download" the crx file instead.catsxp 写了: 2023年 5月 19日 12:49 extensions page
上次由 s6nonqxt9y886fdp 在 2023年 5月 19日 15:33,总共编辑 1 次。
Turn on Developer Mode
The extension has been installed. Thank you.
上次由 s6nonqxt9y886fdp 在 2023年 5月 19日 15:35,总共编辑 1 次。
