tab design
darkhorse
tab design
帖子 darkhorse »
1)
화면 캡처 2025-11-20 163550.png (2.98 KiB) 查看 994 次
2)
화면 캡처 2025-11-20 163531.png (3.67 KiB) 查看 994 次
I changed theme which image is normal?
Re: tab design
What is the intended meaning to convey?
darkhorse
Re: tab design
帖子 darkhorse »
화면 캡처 2025-11-20 163104.png (15.32 KiB) 查看 973 次
As you can see the 1px horizontal line.
I don't know it's intended or should go down 1px lower
Re: tab design
Have you installed a theme extension? If so, it might be a compatibility issue with that extension
Re: tab design
Due to kernel changes, there will be underscores (waiting for Google official resolution)
Can be temporarily adjusted catsxp://settings/catsxpTab The margin inside is 0
darkhorse
Re: tab design
帖子 darkhorse »
Thank you but magrin margin 0 doesn't work but it's not a big deal.
I changed theme which has less strong color. with this color it's almost invisible.
