v 5.11.4 on Windows 7 64 bit
I found 3 bugs:
1) sometimes it does not start, only two small catsxp.exe processes are present in Windows task manager; need to be killed manually and start again
2) browser task manager (shift+esc) is displayed in white color, even with dark theme
3) when I try to install the offline package with unpacked setup.exe and chrome.7z (setup.exe --system-level --verbose-logging), nothing happens; I had to use an older version of setup.exe from Catsxp 137 to make it work.
5.11.4 bugs
Re: 5.11.4 bugs
1.I did not encounter this situation in the local Win7 virtual machine test, although some users have reported this situation, it may also be because I use Win7 less
2.Chrome is also in this situation, this should be a kernel issue
3.5.11.5 fixed!
3.5.11.5 fixed!
Jeffhere
- 来自: Seattle, WA USA
Re: 5.11.4 bugs
I can confirm #1 bug, but it's been happening prior to this version.redfox 写了: 2025年 11月 5日 04:26 v 5.11.4 on Windows 7 64 bit
I found 3 bugs:
On version: Catsxp 5.10.4 (Official Build) (64-bit) it also happens.
Re: 5.11.4 bugs
Did this situation generate a dump file?Jeffhere 写了: 2025年 11月 5日 07:51I can confirm #1 bug, but it's been happening prior to this version.redfox 写了: 2025年 11月 5日 04:26 v 5.11.4 on Windows 7 64 bit
I found 3 bugs:
Can you confirm which version started to have this issue?
- 来自: Czech Republic
Re: 5.11.4 bugs
No dump file. As far as I remember, the #1 bug exists since about v. 139.
上次由 redfox 在 2025年 11月 5日 14:58,总共编辑 1 次。
Re: 5.11.4 bugs
Although I don't often use Win7, I have never encountered this situation during my testing and development for so long. It doesn't generate dump files, so it's a bit troublesome to handle
Scenario 1: Implemented a newly added feature in m139 that is not supported by Win7 (theoretically causing a dump)
Scenario 2: GPU Process Compatibility Issues,Especially with new core on Win 7, the GPU process fails to start, causing the main process to hang.
try:Is this situation occurring frequently? Add the launch parameter --disable-gpu to disable hardware acceleration.
Scenario 3: Extension that is not supported by Win7 was executed
try:Please help test temporarily disabling all extensions and scripts to see if it can solve the problem
Re: 5.11.4 bugs
The same extensions work with Catsxp 137, so it must be something new in the core or Win7 compatibility. Maybe the Win7 in the virtual machine does not behave like the "original" system.
GPU issues nearly always generate dump files, so I pretend it would not be the cause of the problem here.
Re: 5.11.4 bugs
This kind of anomaly without any feedback is the most difficult to fix
And it's also a specific issue on Win7!
Re: 5.11.4 bugs
Has the desktop capture extension been installed?redfox 写了: 2025年 11月 5日 21:57 The same extensions work with Catsxp 137, so it must be something new in the core or Win7 compatibility. Maybe the Win7 in the virtual machine does not behave like the "original" system.
