110.3.1.4版不能在WIN7运行
Re: 110.3.1.4版不能在WIN7运行
在解决了!有细节没处理到位,
得安装一下虚拟机先测试一下再发布!
得安装一下虚拟机先测试一下再发布!
帮测试一下 beta-8
如果还不行 添加启动参数
--no-sandbox
然后再帮我测试一下!
如果还不行 添加启动参数
--no-sandbox
然后再帮我测试一下!
Jeffhere
- 来自: Seattle, WA USA
I received the same error running W764 bit.
Today I updated from 3.1.3 that worked to 3.1.4 beta 8 (portable 64bit) and failed in a similar way...
try beta-9Jeffhere 写了: 2023年 1月 10日 03:32 I received the same error running W764 bit.
有空帮测试一下Beta-9 在win7下的表现!懒得再去弄虚拟机测试了,虚拟机也测不出隐藏很深的Bug!
Jeffhere
when I downloaded, the version is up to 3.1.4 beta 12.
Indeed, it now works again with W7. Thanks.
I enabled the flag Catsxp auto translate but it would not automatically translate this forum for me...i also applied Enable Chromium Translate feature as the description notes, but no change. No auto translate.
Automatic translation is enabled by default, and you don't need to set it again!Jeffhere 写了: 2023年 1月 10日 15:40when I downloaded, the version is up to 3.1.4 beta 12.
This is just a switch. It is the same as the function of the old version, but it is only given a new flag, which can be customized
Jeffhere
I don't get it as no matter the flag setting (enabled or default), the translation is not happening automatically. I have to right click translate to make it happen.catsxp 写了: 2023年 1月 10日 07:20
but Catsxp auto translate should do it "automatically" without my intervention, right?
