Address bar
Rag
Address bar
帖子 Rag »
5.10.1 beta-3
Please return the address bar color to the same as in 5.10.1 beta-2.
图片 图片
Re: Address bar
Switch color scheme to your favorite color
I don't plan to modify the relevant content anymore, as it will fix the color and not change with the theme color
This is unreasonable. When changing the theme color, the color should also change accordingly
截屏2025-09-23 23.16.09.png (113.71 KiB) 查看 770 次
Rag
Re: Address bar
帖子 Rag »
catsxp 写了: 2025年 9月 23日 23:19 This is unreasonable.
Why is this not reasonable?
According to what, the colors set by Chrome?
Why should Catsxp lose its distinctiveness from Chrome and become like the rest? Like the rest of the gray mass.
If you don't want to keep the color from previous versions, then at least make it less vibrant.
Re: Address bar
The old logic was to fix the color values, which would not change with the theme color. As for the issue that the default color is too bright, optimize it later
Rag
Re: Address bar
帖子 Rag »
5.10.1 beta-4
Excellent!
Even better than before.
You're the best! :D
Rag
Re: Address bar
帖子 Rag »
I'm sorry, but you've reverted the address bar color back to bright in 141.5.10.2.
Could you please return it to the color it had in 141.5.10.1?
Re: Address bar
Lowering it will cause color contrast to be out of balance in other places. It is a global parameter, and setting a fixed value will not change the theme color.
