windows 10
v 5.9.1
It doesn't appear even in private mode, so it's likely not caused by an extension.
The comment section is visible in Chrome.
Comments aren't loading even on short videos.
YouTube comments are not displayed.
uukkk
- 2025-09-07 020328.png (40.57 KiB) 查看 570 次
Re: YouTube comments are not displayed.
Ad blocking? Have you ruled out the influence of extensions?
uukkk
I ran it in private mode to eliminate the influence of extensions, but the result remained unchanged.
Error Log
Error Log
custom-elements-es5-adapter.js:11
Uncaught Error: Constructing ytd-comments:
TypeError: Cannot set property scrollParent of #<HTMLElement> which has only a getter
at new g (custom-elements-es5-adapter.js:11:150)
at _.t6 (rs=AGKMywGH59E_2SlJvG7WtM_MpcvC5mEbMQ:12032:203)
at c.createComponent_ (rs=AGKMywGH59E_2SlJvG7WtM_MpcvC5mEbMQ:12061:102)
at c.stampDomArray_ (rs=AGKMywGH59E_2SlJvG7WtM_MpcvC5mEbMQ:12057:168)
at c.rendererStamperApplyChangeRecord_ (rs=AGKMywGH59E_2SlJvG7WtM_MpcvC5mEbMQ:12050:13)
at c.rendererStamperObserver_ (rs=AGKMywGH59E_2SlJvG7WtM_MpcvC5mEbMQ:12047:149)
上次由 uukkk 在 2025年 9月 7日 15:31,总共编辑 1 次。
uukkk
Resetting catsxp://flags/ fixed the issue.
