Browser is highly unstable
iamwearingasuitofham
帖子 iamwearingasuitofham »
Hello, it seems the current update has many errors and bugs which makes it very unstable. The syncing with google and other services are not working, there are frequent crashes, freezing, tearing while transfering between browser windows. As well as settings get reset to default many times.
owgame
Re: Browser is highly unstable
帖子 owgame »
iamwearingasuitofham 写了: 2025年 9月 2日 02:55 Hello, it seems the current update has many errors and bugs which makes it very unstable. The syncing with google and other services are not working, there are frequent crashes, freezing, Drift Hunters tearing while transfering between browser windows. As well as settings get reset to default many times.
If stability doesn’t improve, consider rolling back to the previous version or doing a clean reinstall. This often fixes corrupted update files.
Seciplaccont
帖子 Seciplaccont »
space waves 写了:
Yeah, I’ve noticed the same issues after the latest update. The browser used to run super smooth, but now it freezes quite often, especially when syncing with Google. Hopefully, the devs release a patch soon.
