В версии v.5.8.3 не работает синхронизация Google! (Google Sync doesn't work in version v.5. 8. 3!)
amnester
帖子 amnester »
Установил версию v.5.8.3 Portable. Заметил, что в этой версии перестала работать синхронизации Google! Флаг (
--catsxp-use-google-sync) прописан в StartupParm.txt . В версии v.5.8.2 такой проблемы не было, всё работало нормально!
Installed version v.5.8.3 Portable. I noticed that Google sync stopped working in this version! The flag (
--catsxp-use-google-sync) is registered in StartupParm.txt . There was no such problem in version v.5.8.2, everything worked fine!
Re: В версии v.5.8.3 не работает синхронизация Google! (Google Sync doesn't work in version v.5. 8. 3!)
机翻 · 通用领域
I will test it locally tomorrow
The m140 kernel has undergone significant changes and has been tested during development. The synchronization function is normal, but there may be further code modifications in the later stages, so we cannot guarantee whether these changes will affect the synchronization function
goto
catsxp://sync-internals/
Check if it is normal
Viewing in the settings will display an exception, waiting to be fixed
amnester
帖子 amnester »
Network
Throttled or Backoff true
Retry Time 2025-08-29 17:47:20 +03
Notifications Enabled false
Status from Last Completed Session
Sync Source GU_TRIGGER
GetKey Step Failed false
Download Step Result Network error (ERR_NAME_NOT_RESOLVED)
5.9.1 beta-1 fixed!
amnester
帖子 amnester »
5.9.1 beta-1 fixed!
Спасибо! Всё заработало! Thanks! Everything worked!
