Disable Autoscroll
mindwork
Disable Autoscroll
帖子 mindwork »
Clicking the middle mouse button brings up the autoscroll icon. I didn't find anything related to Autoscroll or the ability to disable it in Settings. Could you add an option to disable Autoscroll? CentBrowser has had a function to disable automatic scrolling for a long time, but unfortunately Catsxp doesn't.
Re: Disable Autoscroll
I don't understand, why is there a demand for this feature?
mindwork
帖子 mindwork »
The enabled autoscroll interferes with some functions that exist in some extensions and scripts. Mainly, this is pasting copied text with the middle mouse button. And also in a very popular extension Tab Session Manager https://chromewebstore.google.com/detai ... glanimpnae opening links in the background happens when you click the middle mouse button. But when you click, autoscroll automatically turns on, and using the opening of links in the background in this extension becomes very difficult. I am sure that users who use the Tab Session Manager extension and other extensions and scripts that use the middle mouse button will be very grateful for the ability to disable autoscroll.
Menu operations such as copy and paste are default behaviors. Why alter them merely to omit a certain step? Especially when it comes to such time-honored default rules, Should respect and adhere to them!
Do require all software in use to follow this change?
Because of the middle button function, Should disable the scrolling function?
mindwork
帖子 mindwork »
No, of course, I'm not asking to completely disable the autoscroll function. I'm asking to add an option to the browser settings to enable/disable autoscroll. Autoscroll, as it is now, will be enabled by default in the browser. It's just that those users who don't need it will simply be able to disable it in the settings.
What's the point of adding non-practical or redundant features? Maintenance requires time and adds unnecessary logic code
selapinka
帖子 selapinka »
mindwork 写了: 2025年 7月 13日 00:10 Clicking the middle mouse button brings up the autoscroll icon. I didn't find anything related to Autoscroll or the ability to disable it in Settings. Could you add an option to disable Autoscroll? CentBrowser has had a function to disable automatic scrolling for a long time, but unfortunately Catsxp doesn't.
You can try doing it manually. I think automatic is not very good sometimes.
GeoGuessr Free Selapinka
josephpotter
帖子 josephpotter »
mindwork 写了: 2025年 7月 13日 06:43 The enabled autoscroll interferes with some functions that exist in some extensions and scripts. Mainly, this is pasting copied text with the middle mouse button. And also in a very popular extension Tab Session Manager https://chromewebstore.google.com/detai ... glanimpnae opening links in the background happens when you click the middle mouse button. But when you click, autoscroll automatically turns on, and using the opening of links in the background in this extension becomes very difficult. I am sure that users who use the Tab Session Manager extension and other extensions and scripts that use the middle mouse button will be very grateful for the ability to disable autoscroll. snow rider
When you click the middle mouse button, autoscroll automatically activates, which makes it very difficult to use these extensions as intended.
It would be greatly appreciated if an option were added to disable autoscroll for users who rely on the middle mouse button for other functions. Thank you!
