系统版本Windows 11 企业版 LTSC 24H2 26100.4652
catsxp 5.7.3
关闭GPU加速没闪屏情况
这个是什么导致的
以下是 catsxp://gpu/ 配置 :
Graphics Feature Status
* Canvas: Hardware accelerated
* Direct Rendering Display Compositor: Disabled
* Compositing: Hardware accelerated
* Multiple Raster Threads: Enabled
* OpenGL: Enabled
* Rasterization: Hardware accelerated
* Raw Draw: Disabled
* Skia Graphite: Disabled
* TreesInViz: Disabled
* Video Decode: Hardware accelerated
* Video Encode: Hardware accelerated
* Vulkan: Disabled
* WebGL: Hardware accelerated
* WebGL2: Hardware accelerated
* WebGPU: Hardware accelerated
* WebNN: Disabled
Version Information
Data exported : 2025-07-11T01:59:05.898Z
Chrome version : Chrome/138.0.7204.101
Operating system : Windows NT 10.0.26100
Software rendering list URL: https://chromium.googlesource.com/chrom ... _list.json
Driver bug list URL : https://chromium.googlesource.com/chrom ... _list.json
ANGLE commit id : df15136b959f
2D graphics backend : Skia/138 a46d5732d9fca93eaec23e502e2eef814b707e6b
Command Line : "C:\Program Files\CatsxpSoftware\Catsxp-Browser\Application\catsxp.exe" --catsxp-microsoft-brand --catsxp-use-google-sync --disable-catsxp-update --disable-catsxp-detect-outdated-install --disable-domain-reliability --enable-dom-distiller --enable-distillability-service --origin-trial-public-key=bYUKPJoPnCxeNvu72j4EmPuK7tr1PAC7SHh8ld9Mw3E=,fMS4mpO6buLQ/QMd+zJmxzty/VQ6B1EUZqoCU04zoRU= --lso-url=https://no-thanks.invalid --variations-server-url=https://www.catsxp.com/api/variations/seed --variations-insecure-server-url=https://www.catsxp.com/api/variations/seed --flag-switches-begin --enable-features=catsxp-override-download-danger-level,catsxp-override-download-insecure-status --flag-switches-end --component-updater=url-source=https://updater.catsxp.com/extensions
Executable path : GetModuleFileNameExA = C:\Program Files\CatsxpSoftware\Catsxp-Browser\Application\catsxp.exe
GetModuleFileNameExW = C:\Program Files\CatsxpSoftware\Catsxp-Browser\Application\catsxp.exe
GetModuleFileNameA = C:\Program Files\CatsxpSoftware\Catsxp-Browser\Application\catsxp.exe
GetModuleFileNameW = C:\Program Files\CatsxpSoftware\Catsxp-Browser\Application\catsxp.exe
Driver Information
Initialization time : 122
In-process GPU : false
Skia Backend : GaneshGL
Passthrough Command Decoder : true
Sandboxed : true
GPU0 : VENDOR= 0x8086, DEVICE=0x7d51 [Intel(R) Arc(TM) 140T GPU (16GB)], SUBSYS=0x3dcf17aa, REV=3, LUID={0,80604}, DRIVER_VENDOR=Intel, DRIVER_VERSION=32.0.101.6104 *ACTIVE*
GPU1 : VENDOR= 0x10de, DEVICE=0x2d19 [NVIDIA GeForce RTX 5060 Laptop GPU], SUBSYS=0x3f9617aa, REV=161, LUID={0,81936}, DRIVER_VERSION=32.0.15.7301
GPU2 : VENDOR= 0x1414, DEVICE=0x008c [Microsoft Basic Render Driver], LUID={0,81629}, DRIVER_VERSION=10.0.26100.4484
NPU0 : VENDOR= 0x8086, DEVICE=0x7d1d, LUID={0,86577}, DRIVER_VERSION=32.0.100.3159
Optimus : false
AMD switchable : false
Desktop compositing : Aero Glass
Direct composition : true
Supports overlays : true
YUY2 overlay support : SCALING
NV12 overlay support : SCALING
BGRA8 overlay support : SCALING
RGB10A2 overlay support : SCALING
P010 overlay support : SOFTWARE
DirectML feature level : 5.0
Driver D3D12 feature level : D3D 12.2
Driver Vulkan API version : Vulkan API 1.4.0
Pixel shader version : 5.0
Vertex shader version : 5.0
Max. MSAA samples : 8
Machine model name :
Machine model version :
GL implementation parts : (gl=egl-angle,angle=d3d11)
Display type : ANGLE_D3D11
GL_VENDOR : Google Inc. (Intel)
GL_RENDERER : ANGLE (Intel, Intel(R) Arc(TM) 140T GPU (16GB) (0x00007D51) Direct3D11 vs_5_0 ps_5_0, D3D11-32.0.101.6104)
GL_VERSION : OpenGL ES 2.0.0 (ANGLE 2.1.25519 git hash: df15136b959f)
GL_EXTENSIONS : GL_AMD_performance_monitor GL_ANGLE_base_vertex_base_instance_shader_builtin GL_ANGLE_blob_cache GL_ANGLE_client_arrays GL_ANGLE_depth_texture GL_ANGLE_framebuffer_blit GL_ANGLE_framebuffer_multisample GL_ANGLE_get_serialized_context_string GL_ANGLE_get_tex_level_parameter GL_ANGLE_instanced_arrays GL_ANGLE_lossy_etc_decode GL_ANGLE_memory_size GL_ANGLE_pack_reverse_row_order GL_ANGLE_polygon_mode GL_ANGLE_program_binary_readiness_query GL_ANGLE_program_cache_control GL_ANGLE_provoking_vertex GL_ANGLE_request_extension GL_ANGLE_robust_client_memory GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ANGLE_texture_usage GL_ANGLE_translated_shader_source GL_APPLE_clip_distance GL_ARM_rgba8 GL_CHROMIUM_bind_generates_resource GL_CHROMIUM_bind_uniform_location GL_CHROMIUM_color_buffer_float_rgb GL_CHROMIUM_color_buffer_float_rgba GL_CHROMIUM_copy_compressed_texture GL_CHROMIUM_copy_texture GL_CHROMIUM_lose_context GL_CHROMIUM_sync_query GL_EXT_EGL_image_external_wrap_modes GL_EXT_base_instance GL_EXT_blend_func_extended GL_EXT_blend_minmax GL_EXT_clip_control GL_EXT_color_buffer_half_float GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_depth_clamp GL_EXT_discard_framebuffer GL_EXT_disjoint_timer_query GL_EXT_draw_buffers GL_EXT_draw_elements_base_vertex GL_EXT_float_blend GL_EXT_frag_depth GL_EXT_instanced_arrays GL_EXT_map_buffer_range GL_EXT_multisampled_render_to_texture GL_EXT_occlusion_query_boolean GL_EXT_polygon_offset_clamp GL_EXT_read_format_bgra GL_EXT_robustness GL_EXT_sRGB GL_EXT_shader_texture_lod GL_EXT_texture_border_clamp GL_EXT_texture_compression_bptc GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc_srgb GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_mirror_clamp_to_edge GL_EXT_texture_norm16 GL_EXT_texture_rg GL_EXT_texture_storage GL_EXT_texture_type_2_10_10_10_REV GL_EXT_unpack_subimage GL_KHR_debug GL_KHR_parallel_shader_compile GL_KHR_robustness GL_NV_EGL_stream_consumer_external GL_NV_fence GL_NV_framebuffer_blit GL_NV_pack_subimage GL_NV_pixel_buffer_object GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_compressed_EAC_R11_signed_texture GL_OES_compressed_EAC_R11_unsigned_texture GL_OES_compressed_EAC_RG11_signed_texture GL_OES_compressed_EAC_RG11_unsigned_texture GL_OES_compressed_ETC2_RGB8_texture GL_OES_compressed_ETC2_RGBA8_texture GL_OES_compressed_ETC2_punchthroughA_RGBA8_texture GL_OES_compressed_ETC2_punchthroughA_sRGB8_alpha_texture GL_OES_compressed_ETC2_sRGB8_alpha8_texture GL_OES_compressed_ETC2_sRGB8_texture GL_OES_depth24 GL_OES_depth32 GL_OES_draw_elements_base_vertex GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_required_internalformat GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_surfaceless_context GL_OES_texture_border_clamp GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_WEBGL_video_texture
Disabled Extensions : GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent
Disabled WebGL Extensions :
Window system binding vendor : Google Inc. (Intel)
Window system binding version : 1.5 (ANGLE 2.1.25519 git hash: df15136b959f)
Window system binding extensions: EGL_EXT_create_context_robustness EGL_ANGLE_d3d_share_handle_client_buffer EGL_ANGLE_d3d_texture_client_buffer EGL_ANGLE_surface_d3d_texture_2d_share_handle EGL_ANGLE_query_surface_pointer EGL_ANGLE_window_fixed_size EGL_ANGLE_keyed_mutex EGL_ANGLE_surface_orientation EGL_ANGLE_direct_composition EGL_NV_post_sub_buffer EGL_KHR_create_context EGL_KHR_image EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_get_all_proc_addresses EGL_KHR_stream EGL_KHR_stream_consumer_gltexture EGL_NV_stream_consumer_gltexture_yuv EGL_ANGLE_stream_producer_d3d_texture EGL_ANGLE_create_context_webgl_compatibility EGL_CHROMIUM_create_context_bind_generates_resource EGL_CHROMIUM_sync_control EGL_EXT_pixel_format_float EGL_KHR_surfaceless_context EGL_ANGLE_display_texture_share_group EGL_ANGLE_display_semaphore_share_group EGL_ANGLE_create_context_client_arrays EGL_ANGLE_program_cache_control EGL_ANGLE_robust_resource_initialization EGL_ANGLE_create_context_extensions_enabled EGL_ANDROID_blob_cache EGL_ANDROID_recordable EGL_ANGLE_image_d3d11_texture EGL_ANGLE_create_context_backwards_compatible EGL_KHR_no_config_context EGL_KHR_create_context_no_error EGL_KHR_reusable_sync EGL_ANGLE_memory_usage_report
Direct rendering version : unknown
Reset notification strategy : 0x8252
GPU process crash count : 0
gfx::BufferFormats supported for allocation and texturing: R_8: not supported, R_16: not supported, RG_88: not supported, RG_1616: not supported, BGR_565: not supported, RGBA_4444: not supported, RGBX_8888: not supported, RGBA_8888: not supported, BGRX_8888: not supported, BGRA_1010102: not supported, RGBA_1010102: not supported, BGRA_8888: not supported, RGBA_F16: not supported, YVU_420: not supported, YUV_420_BIPLANAR: not supported, YUVA_420_TRIPLANAR: not supported, P010: not supported
GPU加速开启的情况下 打开软件会闪屏
Re: GPU加速开启的情况下 打开软件会闪屏
显卡驱动是联想官方最新的 chrome://flags/#use-angle 我这边猫眼浏览器修改至D3D9 和 OpenGL不闪屏
我没记错的话之前启动是不闪屏的 更新过系统 浏览器版本 驱动没动
这个问题大概率是显卡驱动兼容性问题
联想?它有实力自研显卡或开发显卡驱动?
请尝试安装A卡或N卡公版最新驱动
联想?它有实力自研显卡或开发显卡驱动?
请尝试安装A卡或N卡公版最新驱动
首先edge没有出现启动闪屏,其次猫眼浏览器 gpu加速功能是可以正常使用的,唯独就是启动闪屏一下(这里描述准确点,软件闪屏!不是系统闪屏! 这能逼死强迫症患者),要说驱动兼容性问题为什么只有猫眼浏览器启动闪屏呢? 还有我对比测试了下旧版本5.6.3 启动闪屏有(测试下来是概率闪屏,也有不少启动时不闪屏 同样开启GPU加速) 但是缓解很多
上次由 Lee 在 2025年 7月 11日 12:48,总共编辑 1 次。
尝试检查一下是不是调用了显卡驱动强制渲染猫眼浏览器主程序了
比如N卡控制面板——管理3D设置里,全局强制图形增强会有这个问题
图形增强关闭的 而且我这边用的核显为首选
试过了 没用 我家里核显的电脑也闪屏什么参数都不带 旧版本闪屏比新版本少 我都试过了 尝试过禁用任何扩展、以及禁用Experiments、删除启动参数、都无效
