Hello, I use the install version. My browser is updated to the lastest (138) and it doesn't work.
I have tried to unistall and re-install, deleting %LOCALAPPDATA%\CatsxpSoftware\Catsxp-Browser
But it still doesn't work, my browser can not be opened.
Please help.
Thank you
BROWSER CAN NOT BE OPENED
Re: BROWSER CAN NOT BE OPENED
win10?
First use the portable version
There have been similar issues reported by users, and the cause has not yet been identified
iamwearingasuitofham
Yes, I am using Windows 10 on a desktop and a laptop. Both are install versions. My desktop as of now doesnt have any problems, but my laptop can't open Catsxp.catsxp 写了: 2025年 6月 20日 08:57 win10?
I have tried using the portable version on my laptop, but it doesn't work as well. sadly
Be careful:
1. Please backup user data first. User data in higher versions of the kernel cannot be used normally in lower versions of the kernel
2. Do not start with default administrator privileges, otherwise it may not start due to security issues
I have turned off administrator privileges. But it still asks me for it?catsxp 写了: 2025年 6月 20日 16:03 Be careful:
I made sure to turn it off in properties, but then when I click the browser's icon, it tells me to grant administrator privileges?
Why need administrator permissions to run the program? Is it set correctly?
I don't know why. But on my 2 computer, one of them doesn't need administrator privileges, while the other force me to apply it when opening (that one is the one that doesn't work)catsxp 写了: 2025年 6月 20日 21:40 Why need administrator permissions to run the program? Is it set correctly?
Uninstall and reinstall with regular permissions. Under normal circumstances, the installation of catsxp should not require administrator permissions!
Yes, I have uninstall and re-install, even using the portable version. But the exe force me to accept UAC (administrator permissions)catsxp 写了: 2025年 6月 20日 23:06 Uninstall and reinstall with regular permissions. Under normal circumstances, the installation of catsxp should not require administrator permissions!
both the installation and the portable version force me to grant permissionscatsxp 写了: 2025年 6月 20日 23:06 Uninstall and reinstall with regular permissions. Under normal circumstances, the installation of catsxp should not require administrator permissions!
