Moved from Cent Browser
trancid
帖子 trancid »
I have a Russian version, so there's can be some misunderstandings with settings.
When I disable Tab-New tab page, open a new tab, press in a search box Catsxp instantly crashes...
crash on searchbox.zip
(87.18 KiB) 已下载 109 次
trancid
Re: Moved from Cent Browser
帖子 trancid »
It seems that a portable version has a problem with updates...
In StartupParm.txt I set as #--disable-catsxp-update and so there's an error at catsxp://settings/help:
"При проверке обновлений произошла ошибка: Не удалось выполнить проверку обновлений (код ошибки: 1: 0X80004005)."
At catsxp://settings/safetyCheck the browser says it's outdated, but it's last version.
Please be more specific, I didn't understand clearly what kind of operation would cause a crash and exit
Did you directly use old user data? Isn't it brand new?
trancid
帖子 trancid »
yeah all brand new and clear
used 64 bit portable.
the error also occurs with the X86 standalone installation package...
here's the link to the video https://cloud.mail.ru/public/WRqb/arM7nWsXU
上次由 trancid 在 2025年 6月 2日 14:31,总共编辑 1 次。
velvetytrack
帖子 velvetytrack »
the X86 standalone installation package encounters the issue.
trancid 写了: 2025年 6月 2日 14:30 yeah all brand new and clear
here's the link to the video https://cloud.mail.ru/public/WRqb/arM7nWsXU Additionally, the X86 standalone installation package encounters the issue.
