Could you add a button to clear all recent tabs?
iamwearingasuitofham
帖子 iamwearingasuitofham »
Hi, through browsing I regularly shared the tabs via multiple instances of Catsxp. Could you implement a button that would clear the recent tabs (like in other chromium browsers)?
Thank you sincerely
Re: Could you add a button to clear all recent tabs?
Isn't there a related operation item in the main menu history?
catsxp 写了: 2025年 5月 25日 11:39 Isn't there a related operation item in the main menu history?
What I was referring to is this. It helps to clear the recent tabs, but won't affect history.
What is the significance of this operation?
The only function of this feature is to add unnecessary junk code
catsxp 写了: 2025年 5月 26日 22:43 What is the significance of this operation?
The feature can be considered a bit of cosmetic. By cleaning recent tab independent of affecting browsing history, user could track the tabs they use better, as if they want to re-sort the tabs or the opened windows of the browser, for example.
Of course, if it is seemed to be a wasteful thing to do, and futile, then you should not do it.
I sincerely thank you for creating a lightweight browser that is modern, fast, filled with tweaks and intergration that other could use.
Thank you
History records have not been cleared, this behavior is like covering one's ears and stealing a bell
