Hello, I'm using Catsxp browser on 2 machines.
I have turned on sync on both machines, but the bookmark and some settings (extensions,...) can't be sync
Can't sync bookmark and settings from 2 Catsxp browsers.
iamwearingasuitofham
- Untitled.png (6.47 KiB) 查看 1838 次
- Screenshot_1.png (18.02 KiB) 查看 1838 次
Re: Can't sync bookmark and settings from 2 Catsxp browsers.
Some custom settings do not exist in the data structure of the synchronization service, so this part of the data cannot be synchronized
But my bookmarks can't be sync? And my extensions too?
I can't sync them?
I can't sync them?
- Screenshot_2.png (173.99 KiB) 查看 1833 次
Attempt to exit the synchronization chain and re-enter
Yes I had just done that. After exit synchronization and then re-enter, I waited for 40 minutes but the bookmarks doesn't sync.
Did all synchronized devices exit the synchronization chain and re-enter??
I just reset the synchronization server yesterday.Need to exit and re-enter the synchronization chain again to recognize it
If you find this troublesome, enable the Google Sync feature
I have turned on google sync (--catsxp-use-google-sync).
Sometimes, on the second machine, the browser lost the sync and signed out of the google account, then the button to sync was gone. I tried to edit the shortcut, but it sometimes failed as well. Startupparm.txt will crash the browser.
I'm using google sync right now, but still not work.catsxp 写了: 2025年 5月 12日 21:07 Did all synchronized devices exit the synchronization chain and re-enter??
Piokang
Is the sync account working properly?iamwearingasuitofham 写了: 2025年 5月 12日 18:35 Hello, I'm using Catsxp browser on 2 machines.
上次由 Piokang 在 2025年 8月 6日 10:20,总共编辑 1 次。
Geometry Dash Piokang
Sometimes it does, most of the time it doesn'tPiokang 写了: 2025年 8月 6日 10:19Is the sync account working properly?iamwearingasuitofham 写了: 2025年 5月 12日 18:35 Hello, I'm using Catsxp browser on 2 machines.
