136.5.5.2 many crash reports, websites not loading
来自: Czech Republic
帖子 redfox »
Version 136.5.2.2 generates many crash reports on Windows 7 x64, most of them just after startup. Also the start time is slow.
Some websites like www.catsxp.com do not load at all (blank page), or only after more tries.
I am sending you the crash reports. Please analyze them and respond here. Thank you.
I am reverting to 135.4.4.3, which is OK.
Re: 136.5.5.2 many crash reports, websites not loading
test ok!
try 5.5.3 beta-1!
来自: Czech Republic
帖子 redfox »
What did you get from my crash reports, Catsxp?
No
Unable to resolve the location reason
Please use beta-1 to reproduce and send the dump to my email
来自: Czech Republic
帖子 redfox »
Sorry I need to use a full installer version to use my profile, not a portable one.
In the meantime I re-tested the version 136.5.5.2, and the number of dump files is approx. the same if AI chat enabled or not. It seems not related to it.
上次由 redfox 在 2025年 5月 2日 02:38,总共编辑 1 次。
Please use the latest beta version to reproduce. This dump file is needed to resolve and locate the issue
来自: Czech Republic
帖子 redfox »
Ok, just sent.
GPU error
chrome://flags/#use-angle
Try changing different values to see if it can be executed normally
If it still doesn't work ..
Please try upgrading the driver program
Normal execution during virtual machine testing
屏幕截图 2025-05-02 073906.png (60.15 KiB) 查看 3183 次
来自: Czech Republic
帖子 redfox »
There was no such error until core 136, maybe they changed something.
Unfortunately. my iGPU has no driver upgrades available for Win7.
I tried all possible values of chrome://flags/#use-angle, no change, except for OpenGL, which freezes the browser completely.
In this version, even going to chrome://flags often displays an empty page with only parts of vertical toolbars. The settings page works more often, but not always. Something is very weird with this version under Windows 7.
I am curious if others have similar problems.
上次由 redfox 在 2025年 5月 2日 10:52,总共编辑 1 次。
在 Windows 7 系统上运行 Chromium 遇到 `GrGLCheckLinkStatus` 失败的问题,通常与 **图形驱动兼容性** 或 **OpenGL 支持** 相关。以下是逐步排查和解决方案:
### **1. 更新显卡驱动**
- **原因**:旧版驱动可能不支持 Chromium 所需的 OpenGL 特性。
- **操作**:
1. 打开 **设备管理器**(右键“计算机” > 管理 > 设备管理器)。
2. 展开 **显示适配器**,右键显卡(如 NVIDIA/AMD/Intel)选择 **更新驱动程序**。
3. 前往显卡官网下载最新支持 Win7 的驱动(部分新驱动可能已不支持 Win7,需确认)。
### **2. 强制 Chromium 使用 DirectX 替代 OpenGL**
- **原因**:Chromium 的 ANGLE 层默认可能尝试使用 OpenGL,而 Win7 的 OpenGL 实现可能存在问题。
- **操作**:
1. 启动 Chromium,在地址栏输入 `chrome://flags`。
2. 搜索以下标志并修改:
- **Choose ANGLE graphics backend** → 改为 **D3D9** 或 **D3D11**。
- 或 **Override software rendering list** → 启用。
3. 重启浏览器。
### **3. 禁用 GPU 加速(临时测试)**
- **原因**:确认问题是否与 GPU 加速直接相关。
- **操作**:
1. 进入 `chrome://settings`,搜索 **使用硬件加速模式**。
2. 关闭该选项,重启 Chromium。
3. 如果问题消失,说明需进一步修复 GPU 相关配置。
### **4. 检查系统 OpenGL 版本**
- **原因**:Chromium 可能需要 OpenGL 3.2+,而旧驱动可能不支持。
- **操作**:
1. 下载工具 [GPU Caps Viewer](http://www.ozone3d.net/gpu_caps_viewer/)。
2. 检查报告的 OpenGL 版本,如果低于 3.2,需更新驱动或更换硬件。
### **5. 安装系统更新和运行时库**
- **原因**:缺少关键系统补丁或 Visual C++ 运行时。
- **操作**:
1. 确保 Windows 7 已安装 **SP1** 和所有可选更新。
2. 安装 [Visual C++ Redistributable 最新版](https://support.microsoft.com/en-us/top ... f26a218cc0)。
3. 安装 [DirectX End-User Runtimes](https://www.microsoft.com/en-us/downloa ... px?id=8109)。
### **总结**
若上述步骤无效,可能是 Win7 平台限制导致的问题。如需进一步调试,可通过 `chrome://gpu` 页面查看详细的图形状态日志。
Here’s an English version of the troubleshooting steps for the **`GrGLCheckLinkStatus` failure in Chromium on Windows 7**, typically related to **graphics driver compatibility** or **OpenGL support**:
### **1. Update Graphics Drivers**
- **Cause**: Outdated drivers may lack support for OpenGL features required by Chromium.
- **Steps**:
1. Open **Device Manager** (Right-click "Computer" > Manage > Device Manager).
2. Expand **Display adapters**, right-click your GPU (e.g., NVIDIA/AMD/Intel), and select **Update driver**.
3. Download the latest Windows 7-compatible driver from the GPU manufacturer’s website (note: newer drivers may no longer support Win7).
### **2. Force Chromium to Use DirectX Instead of OpenGL**
- **Cause**: Chromium’s ANGLE layer might default to OpenGL, which may have compatibility issues on Win7.
- **Steps**:
1. Launch Chromium and navigate to `chrome://flags`.
2. Modify the following flags:
- **Choose ANGLE graphics backend** → Set to **D3D9** or **D3D11**.
- **Override software rendering list** → Enable.
3. Restart the browser.
### **3. Disable GPU Acceleration (Temporary Test)**
- **Cause**: Determine if the issue is GPU-related.
- **Steps**:
1. Go to `chrome://settings`, search for **Hardware Acceleration**.
2. Disable the option and restart Chromium.
3. If the problem resolves, further GPU configuration is needed.
### **4. Check System OpenGL Version**
- **Cause**: Chromium may require OpenGL 3.2+, which older drivers might not support.
- **Steps**:
1. Use tools like [GPU Caps Viewer](http://www.ozone3d.net/gpu_caps_viewer/) to check the OpenGL version.
2. If the version is below 3.2, update drivers or consider hardware upgrades.
### **5. Install System Updates and Runtime Libraries**
- **Cause**: Missing critical Windows updates or runtime dependencies.
- **Steps**:
1. Ensure Windows 7 **SP1** and all optional updates are installed.
2. Install the latest [Visual C++ Redistributable](https://support.microsoft.com/en-us/top ... f26a218cc0).
3. Install [DirectX End-User Runtimes](https://www.microsoft.com/en-us/downloa ... px?id=8109).
### **Debugging Tips**
- Check detailed graphics status at `chrome://gpu`.
- If issues persist, capture logs by running Chromium with `--enable-logging --v=1` flags.
Let me know if you need further assistance! 🛠️
