Catsxp developer, please, could you add a possibility to the settings, to use only custom filters lists, without built-in ad filters enabled?.
Thanks in advance.
Enable only custom filters without general ad filtering on
- 来自: Czech Republic
Re: Enable only custom filters without general ad filtering on
catsxp://settings/shields/filters
- catsxp_screenshot_settings.png (152.87 KiB) 查看 3293 次
Thank you. I know this settings, but when I set up my filters and NOT enable ad blocking on the previous page, the custom filters are not applied.
In general, there are 3 options:
- leave ad blocking disabled, so no filters are applied at all
- enable ad blocking without custom filters, so only the default Catsxp filters are applied
- enable ad blocking and custom filters, so all the default Catsxp and custom filters are applied
But, there is no such option:
- leave ad blocking disabled, and apply only the custom filters.
I don't understand. Custom filtering rules don't take effect?
I'd like to keep built-in Catsxp filters turned off, and use only the custom filters I defined.
上次由 redfox 在 2025年 4月 21日 03:46,总共编辑 1 次。
Catsxp currently does not have built-in filtering rules
If you want to close globally, please set:
catsxp://settings/catsxpContent (Trackers & ads blocking =>Disabled)
Ah, I get it. I thought there is some built-in ad blocking in Catsxp. So, there is no problem.
Thank you for your explanation.
