Cloudflare blocks access to the site, cloudflare tests fail, re - captcha in loop, while in Supermium there are no cloud
drimisone
帖子 drimisone »
Hi, thank you so much for the new updated versions of Catsxp !
So, i see sometimes the issues of Cat cat extension and a chinese user says he can't download videos from this site which is a chinese site :
https://ddys.site/
i try to access this chinese site via Chromium but the same problem cloudflare blocking comes back, there is re-captcha of cloudflare in loop,
i try with Supermium and i have no problem accessing this site ddys.site/ ,
i try with the latest version of catsxp browser but i can't access this chinese site, same problem of re captcha of cloudflare in loop :(
i tried also with my favourite anime french website and also, sadly there is re captcha of cloudflare in loop....
we hope this problem will be fixe please, thanks :)
it seems cloudflare blocks independent browsers, I think Chromium browsers have to see the supermium browser code, maybe supermium uses a special user agent to avoid cloudflare loop re captcha....
Let's note an interesting thing, in the release notes of basilisk browser:
https://www.basilisk-browser.org/releasenotes.html
"Unfortunately CloudFlare has deployed scripts since the last Basilisk release that deliberately cause issues on independent browsers. If you are interested in learning more, check out the Pale Moon Forum thread where users are discussing this issue. Please consider reporting any and all occurrences of failing or looping CloudFlare checks on websites to CloudFlare as well as the owners of affected websites (you may have to temporarily use a Chromium-based browser to do this)."
Re: Cloudflare blocks access to the site, cloudflare tests fail, re - captcha in loop, while in Supermium there are no c
Local test results
Using Chromium | Brain | CatsXP
After the first visit to CloudFlare, There will be no revalidation of cloudflare in the loop
I personally think this is the cloudflare mechanism, which will repeatedly verify if it deems it unsafe
csix
帖子 csix »
开启硬件加速试试
drimisone
帖子 drimisone »
Yes but in this case, why does cloudflare authorize supermium to connect without problem to this site me the user who is in north africa, but does not authorize catsxp from north africa? has cloudflare blacklisted catsxp?
this is general problem, even in special chrome 130 for windows 7 os, I had cloudflare loop problem....
and i have the same problem cloudflare loop in chromium 133/134/125 for windows 7, a Chinese user in China Mr @ZepopaOwleMukasa confirmed to me that he cannot access this site by telling me:
"I can confirm, I too run into an infinite cloudflare captcha loop on that website. However, on a clean chromium install with a freshly created user data directory and no changes to settings or any installation of extensions, I pass through successfully without issue."
https://github.com/e3kskoy7wqk/Chromium ... 2704877919
So with supermium 126 browser, without using a vpn, (i.e. the same IP address), I can access this site without problem or cloudflare loop in supermium....
it's really strange this problem, maybe because supermium uses chromium 126 LTS there is no problem re captcha cloudflare in loop ?.....and maybe Mr Catsxp you are in china that's why there is no problem to access this site in chromium, maybe cloudflare consider chromium from north africa which accesses a chinese site it's suspicious.....and maybe supermium 126 LTS changes its user agent, or dns mechanism I don't know....
Mr Catsxp , are you using particular dns ? or are you using ublock origin lite or mafest v2 ?
me i use ublock origin lite and netcraft extension that block malware phshing sites....
I changed my ISP's dns to quad9 dns....it's strange, the last time I was able to access a French site protected by cloudflare when I restarted my internet box and my computer....
I also specify that I disabled ipv6 in windows os, my internet box does not support ipv6 in addition it says ipv6 can influence the proper functioning and filtering of ipv4 because I need an effective quad9 ipv4 dns fully functional against malware viruses especially since I do not have an antivirus in my windows 7 os 32 bits...
we will be fixed on this problem if other users outside of China try to access this site using chromium....
macyoyo
帖子 macyoyo »
csix 写了: 2025年 3月 7日 08:59 开启硬件加速试试
开不开都试过了,都不管用
欢迎来到穿墙导航cqdh.top
macyoyo
帖子 macyoyo »
我找到问题了,我吧所有插件禁用了,然后一个一个测试,发现 “暴力猴脚本”有问题,在排除了暴力猴的插件内容,是一个叫做“音视频增强脚本”的脚本文件造成,只要关掉就能正常验证了。
插件的脚本github页面已经有人提出这个问题了,等待他们修正吧,不是浏览器的问题。
插件地址https://github.com/xxxily/h5player
上次由 macyoyo 在 2025年 3月 7日 21:34,总共编辑 1 次。
欢迎来到穿墙导航cqdh.top
来自: Czech Republic
帖子 redfox »
Supermium presents itself as Chrome, so it has no problems.
The same with DRM/Widevine support.
drimisone
帖子 drimisone »
Ohh thank you very much for this solution Mr Macyoyo! and also thanks to Mr Csix for his suggestion!
Hoping that this problem will be fixed soon, here is my own idea that I posted in another issue today ! :
"This is official, i find the origin of cloudflare problem in Catsxp, i go to supermium settings and i find this feature anti robot anti captcha which allows sites to verify that we are not robots and thus avoid captchas:
there is anti robot option:
Chrome://Settings/Contents/AutoVERIFY
But in Catsxp browser, i can't find this capital feature to avoid captcha:
I think our beloved Catsxp should implement this feature to avoid cloudflare re captcha loop, thanks "
