Changing Avatar Profile Pictures (catsxp://settings/manageProfile)
MidnightRu
帖子 MidnightRu »
I can't find the resources responsible for the images of each profile catsxp://settings/manageProfile. How can I change all the images to my PNGs? In the CENT browser, this could be easily done by replacing the PNG images in the "User Data\Avatars" folder. This is changed in Chrome in the same way.
Please make this function available in future versions, if the current one doesn't have this feature, or I haven't found how.
Note: I only use the portable x64 version
Cent Avatars.jpg (84.9 KiB) 查看 3208 次
Re: Changing Avatar Profile Pictures (catsxp://settings/manageProfile)
This resource exists in a packaged form and will not be independently extracted into a folder
MidnightRu
帖子 MidnightRu »
catsxp 写了: 2025年 2月 15日 08:58 This resource exists in a packaged form and will not be independently extracted into a folder
Tell me where exactly this resource is located and is it possible to edit it?
I would like to implement the function of my own photos/profile images.
primatey41
帖子 primatey41 »
Thanks for bringing this up—I've actually wondered about this too while using the portable x64 version. Would love the ability to customize avatars with my own PNGs like in Chrome or Edge (via User Data\Avatars). It's a small feature, but makes a big difference in personalization.
Can Chrome modify user avatars locally?
Can you?
Enable Google Sync to automatically sync account user avatars
