Impossible to install the new update
drimisone
帖子 drimisone »
Hi, I visit the Catsxp website and I see that there is a new update, happy, I click on:
help:
catsxp://settings/help
Catsxp updates itself then displays a message "the update is almost complete, restart the browser to apply it?", I click of course on yes, and Catsxp restarts but the new update is not applied and I have the same message which is displayed again and again after 7 restarts and many attempts to update by clicking again and again on catsxp://settings/help!
we hope this bug will be resolved please, otherwise we must uninstall Catsxp and install a fresh version of the new version of Catsxp?
I use windows 7 os 32 bits .
Re: Impossible to install the new update
drimisone
帖子 drimisone »
Oups I'm confused, I saw in the main page of Catsxp browser the version 5.1.2 displayed and I thought it was the new stable version that's why I decided to install the update, then I checked on softtpedia site and it says version Catsxp 5.1.2 is a beta version....
I prefer to install only the stable version on my weak eee pc, I uninstalled to reinstall Catsxp but now, I can't find the stable version....
Usually the history page only displays the stable version:
https://www.catsxp.com/history
so where can we find the stable version please i.e. version 5.1.1?
drimisone
帖子 drimisone »
Thanks, I only use the executable version, I have never used the portable version....
well I think I will install the new executable version beta chromium 132, I have no choice, in addition this version seems promising
