Telegram audio
casdcoast
Telegram audio
帖子 casdcoast »
The last few releases don't want to play audio on Telegram in the browser.
The current version is 4.12.3 x64 windows.
Re: Telegram audio
Can you provide a detailed description of the problem
I don't understand
Can't play audio?
casdcoast
Re: Telegram audio
帖子 casdcoast »
Yes the audio will not play.You click on any audio file and it will attempt to play but doesn't.
A few versions back the audio was fine.
Re: Telegram audio
The relevant certificates cannot be obtained and there is currently no solution
Previously, it played normally because the website did not use a certificate for audio encryption
