Thick frame
Jasantes
Thick frame
帖子 Jasantes »
Is there a way to change the thick frame around tab cards (also translator options and extensions)?
In Chromium is disabling graphics acceleration, but not in Catsxp. See the capture:
[/img]
Re: Thick frame
Win7
Do not enable parameters
--disable-dwm-composition
Jasantes
Re: Thick frame
帖子 Jasantes »
In catsxp://flags doen't exist disable-dwm-composition.
With --disable-dwm-composition parameter in command line shortcut not working.
Sistema operativo Windows 7 Service Pack 1 (Build 7601.24385)
JavaScript V8 13.2.152.18
User-agent Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36
Línea de comandos "G:\CatsXP\CatsXP\catsxp.exe" --disable-catsxp-update --disable-domain-reliability --disable-encryption-win --disable-machine-id --disk-cache-dir="G:\CatsXP\CatsXP\Cache" --enable-distillability-service --enable-dom-distiller --lso-url=https://no-thanks.invalid --origin-trial-public-key=bYUKPJoPnCxeNvu72j4EmPuK7tr1PAC7SHh8ld9Mw3E=,fMS4mpO6buLQ/QMd+zJmxzty/VQ6B1EUZqoCU04zoRU= --user-data-dir="G:\CatsXP\CatsXP\User Data" --variations-insecure-server-url=https://www.catsxp.com/api/variations/seed --variations-server-url=https://www.catsxp.com/api/variations/seed --restart --user-data-dir="G:\CatsXP\CatsXP\User Data" --disk-cache-dir="G:\CatsXP\CatsXP\Cache" --disable-catsxp-update --disable-encryption-win --disable-machine-id --disable-domain-reliability --enable-dom-distiller --enable-distillability-service --lso-url=https://no-thanks.invalid --flag-switches-begin --enable-features=OmniboxTabSwitchByDefault --disable-features=CatsxpNewsCardPeek,EnableTabMuting,MultiTabOrganization,NtpCalendarModule,TabGroupsSaveUIUpdate,TabReorganization,TabReorganizationDivider --flag-switches-end --component-updater=url-source=https://updater.catsxp.com/extensions,u ... extensions
Ruta del ejecutable G:\CatsXP\CatsXP\catsxp.exe
Ruta del perfil G:\CatsXP\CatsXP\User Data\Default
Re: Thick frame
Close win7 aero?
Jasantes
Re: Thick frame
帖子 Jasantes »
No way... disabled DWM service, desktop composition in the shortcut Properties > Compatibility (Aero) and added --disable-dwm-composition to exe shotcut.
Re: Thick frame
Open Aero + del (--disable-dwm-composition)
Reverse Operation?
Jasantes
Re: Thick frame
帖子 Jasantes »
I have customed theme, Aero disabled.
--disable-dwm-composition > where?
Re: Thick frame
Turning off Aero will cause shadow black edges
Jasantes
Re: Thick frame
帖子 Jasantes »
Sorry, I give up...
I hope this will be fixed in the settings.
