[Catsxp Dark] file:/// path support
yylly
帖子 yylly »
With "file:///C:/example/例子.html" open, Catsxp Dark displays the following:
This affects all "file:///" URIs.
Instead, I would like for it to function like this:
(NOTE: I used "DevTools" to edit the path text, as a demonstration.)
My hope is to be able to toggle each unique "file:///" URI. This is because some require different settings to display correctly.
Though, due to the way Dark Reader works, the full path might not be doable.
So, while this is less ideal, maybe it could work based on filename:
Whether or not this feature is able to be added, I'd like you to know that I appreciate all of your hard work. Catsxp is an amazing browser. Thank you.
I only speak English. If you don't understand what I say, please tell me and I will find a friend who speaks Chinese and English to help me translate.
( 我只会说英语。如果你听不懂我说什么,请告诉我,我会找一个会说中文和英文的朋友帮我翻译。 )
Re: [Catsxp Dark] file:/// path support
The built-in dark is a temporary transition and will not be used continuously. Optimizing it is of little significance
yylly
帖子 yylly »
catsxp 写了: 2024年 10月 29日 03:56 The built-in dark is a temporary transition and will not be used continuously. Optimizing it is of little significance
So it will be replaced with something better? I really enjoy how it can apply a dark theme pages that normally can't be affected. For example: Chrome Web Store and chrome:// URIs.
I hope whatever it is replaced with is able to do the same.
By the way, I'm still affected by this every time I post: "This post is not visible to other users until it has been approved by a moderator."
Would you please update my account so that I don't experience this anymore?
上次由 yylly 在 2024年 11月 2日 22:07,总共编辑 1 次。
Posts must be reviewed to avoid unnecessary trouble caused by inappropriate user comments
