[IMPORTANT][EASY][CODE INCLUDED] Startup parameter: preserving Browser History which is older than 90 days
yylly
帖子 yylly »
https://codeberg.org/ungoogled-software ... tion.patch
This patch adds this startup parameter: "--keep-old-history"
Browser History which is older than 90 days will be preserved, instead of being automatically removed.
Extremely needed!
I only speak English. If you don't understand what I say, please tell me and I will find a friend who speaks Chinese and English to help me translate.
( 我只会说英语。如果你听不懂我说什么,请告诉我,我会找一个会说中文和英文的朋友帮我翻译。 )
Re: [IMPORTANT][EASY][CODE INCLUDED] Startup parameter: preserving Browser History which is older than 90 days
I do not agree with the practicality of this feature. Excessive historical records can seriously affect users' daily use and pose a severe challenge to synchronous server retrieval
yylly
帖子 yylly »
catsxp 写了: 2024年 10月 14日 06:09 I do not agree with the practicality of this feature. Excessive historical records can seriously affect users' daily use and pose a severe challenge to synchronous server retrieval
Are you referring to the address bar?
I wonder if it would be possible to limit what the address bar retrieves by the age of the history entry.
I want this feature because I very often forget a place I've been to, say, 4 months ago. Like if I left off on an episode of a particular series, for instance.
As an aside that's unrelated to this feature request, it's always annoyed me that the address bar only retrieves 3 items from the Browser History. I wish it retrieved more than that.
Y
Excessive historical entries can seriously affect performance and user experience
yylly
帖子 yylly »
catsxp 写了: 2024年 10月 14日 11:23 Y
I'm not sure if this means "Yes" or "Why?"
In any case...
If you ever think up a way to have an "archived" Browser History that doesn't affect performance, I would really appreciate that.
This is impossible to achieve
When manually entering a website address in the address bar, it will automatically search for history records
Too many historical records may result in lagging pages, fake deaths, and other issues
yylly
帖子 yylly »
Okay, thanks anyway.
