Chromium v120 and up is meant to have shader-f16 by default, but it won't be listed in features here: https://webgpureport.org/
See: https://github.com/mlc-ai/web-llm/issue ... 1877115608
I need this feature for use with @mlc-ai/web-llm, please include it in an update. Thank you.
shader-f16 not supported by browser
yylly
I only speak English. If you don't understand what I say, please tell me and I will find a friend who speaks Chinese and English to help me translate.
( 我只会说英语。如果你听不懂我说什么,请告诉我,我会找一个会说中文和英文的朋友帮我翻译。 )
Re: shader-f16 not supported by browser
Same kernel m129 in Chrome and CatsXP
The test results are consistent
yylly
When you go to this site, does it show shader-f16 in the "features" section? (Bottom of the middle column.)
上次由 yylly 在 2024年 9月 18日 13:59,总共编辑 1 次。
M120+ confirmed default support?
yylly
https://chromestatus.com/feature/5180552617656320
https://developer.chrome.com/blog/new-in-webgpu-120
上次由 yylly 在 2024年 9月 19日 02:01,总共编辑 1 次。
// List of WebGPU feature names, delimited by ,
// The FeatureParam may be overridden via Finch config, or via the command line
// For example:
// --enable-field-trial-config \
// --force-fieldtrial-params=WebGPU.Enabled:UnsafeFeatures/timestamp-query%2Cshader-f16
// Note that the comma should be URL-encoded.Attempt to add startup parameters:
The test results show that it is not yet open
Are you sure the test results of this page are valid under win? (Mac testing?)
catsxp://gpu/
[Adapter Supported Features]
* depth-clip-control
* depth32float-stencil8
* timestamp-query
* texture-compression-bc
* indirect-first-instance
* shader-f16
* rg11b10ufloat-renderable
* bgra8unorm-storage
* float32filterable
* subgroups
* subgroups-f16
* dawn-internal-usages
* dawn-multi-planar-formats
* dawn-native
* implicit-device-synchronization
* surface-capabilities
* unorm16texture-formats
* snorm16texture-formats
* multi-planar-render-targets
* adapter-properties-memory-heaps
* adapter-properties-d3d
* format-capabilities
* norm16texture-formats
* shared-texture-memory-dxgi-shared-handle
* shared-fence-dxgi-shared-handle-
yylly
My apologies, it turned out to be a hardware issue, apparently my card doesn't support shader-f16. Very sorry.
