3.3.5 beta-2 on W8.1 64bit
Crashed regardless of having --no-sandbox or not. I tried adding --no-sandbox via both StartupParm.txt or catsxp --no-sandbox on the Command Prompt.
Re: 3.3.5 beta-2 on W8.1 64bit
Win8.1 has not been tested! Win7 virtual machine can be used normally after correct addition and startup!
StartupParm.txt:
--user-data-dir=./User Data
--disk-cache-dir=./Cache
--disable-catsxp-update
--disable-machine-id
--disable-encryption-win
--no-sandbox
catsxp 写了: 2023年 3月 21日 10:48 StartupParm.txt:
--no-sandbox
As I said, I'm already tried this.
try beta-3
If there is an abnormal crash, please send the dump file to my mail
catsxp 写了: 2023年 3月 21日 15:29 try beta-3
beta-3 also crashed and there is indeed no dump file to send to you.
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
s6nonqxt9y886fdp 写了: 2023年 3月 21日 19:58
ensure you have Automatically send diagnostic reports under the Privacy and security settings section enabled....
User Data\Crashpad\reports\
Crash confirmation will generate a dump file!
Win7 virtual machine test is normal!
Win8 has not been tested! It seems that we also need to install a virtual machine!
Let me install a local Win8 virtual machine measurement fix!
I think the dump file should be placed next to catsxp.exe like other applications. I will check again.
3.3.5 beta-4 also failed the same way. This time I will not send you the dump file like the previous time. I will just accept that catsxp no longer work on my system. I switched to Firefox. Goodbye.
