Possible Bug in Settings?
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
Using v4.9.5 Beta-3 (W7-64bit), but not sure if this is a bug and/or it may have happened in a previous version.
Occasionally on a rev change, I check settings.
I first noticed the content - page zoom was set to 25% (although my default was 110%). The 25% was not affecting web pages. I reset to 110%
Checking other settings under Performance - general, Tab hover preview card appearance, I click the setting but it takes me to:
Appearance settings but there is nothing about Choose to show memory usage and images in the tab hover preview card in those sections.
Is a link pointing to an incorrect setting??
Jeffhere
来自: Seattle, WA USA
Re: Possible Bug in Settings?
帖子 Jeffhere »
similarly, under Accessibility - Caption preferences....
click it, nothing happens where it should lead to
Customize caption size and style for Live Caption
thanks!
4.9.5 beta-4 fixed!
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
Jeffhere 写了: 2024年 9月 15日 02:19 similarly, under Accessibility - Caption preferences....
this one still does nothing for me. click it and zippo!
This feature is currently not functioning properly and it is unclear which aspect is causing the issue
