download error when installing all extensions
pgcatsxp
帖子 pgcatsxp »
i downloaded both 32-bit and 64-bits of portable of version v 4.9.1
however i totally cannot install any extensions from https://chromewebstore.google.com/category/extensions
below is the full error
Download error: Download interrupted
Re: download error when installing all extensions
Tested normally
Please try to exclude the impact of extensions or scripts
pgcatsxp
帖子 pgcatsxp »
Sorry but I don't understand what do you mean.
Can you please explain in more simple method
I am using Windows 11 Version 23H2 (OS Build 22631.4037)
上次由 pgcatsxp 在 2024年 9月 4日 13:59,总共编辑 1 次。
sollera
帖子 sollera »
Most portable Chromium builds do not support installing from the Chrome Web Store directly, because they:
Disable Google account sync
Don’t use the official Google API keys
Block extension updates from Google’s servers
Rag
帖子 Rag »
sollera
Don't write nonsense.
I have always used and use only portable versions of Chromium browsers and have never used Google sync.
Always installed extensions from the online store.
Blocking extensions has never affected or affects the installation of new extensions.
pgcatsxp
ALWAYS test on a clean profile.
Extensions from the store are installed without problems.
