Question/help needed
分享点滴经验
damdidum
帖子 damdidum »
I just had a question - When it comes to portable releases, I have using the x64 version. I usually just remove the older version portable, download the new version portable and copy the Cache and User data from the old portable into the new portable. However, when I delete older version portables by dragging to recycle bin on windows, it leaves registry keys of old version that I have to manually delete - is there a more 'effective' or 'responsible' way of deleting each portable version?
Thank you (and also thank you for your hard work).
Re: Question/help needed
why?
Simply copy and overwrite files other than StartupParm.txt
It is not recommended to create a new folder and recreate a new version of the portable version
damdidum
帖子 damdidum »
Will do, thanks!
