No Stats Display on New Tab Page
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
noticed the Shield stats are not displaying on the New Tab Page, although selected.
Had custom backgrounds, tried with just Catsxp colors. No change.
Tried turning off, Catsxp stats, then back on. no change.
Tried with versions 4.81, 4.83 and now 4.91 beta 3. No change.
W7 64 bit.
update: on another pc, it works ok....so there must be a setting difference?
The ok screen uses 1920x1080 where the "not OK screen" uses 1366x768
I tried with --disable-direct-write and also removing that parameter on the "not OK screen" no change, on small laptop, I still don't see ads blocked/data saved....but the time clock is fine.
Other possibilities??
Jeffhere
来自: Seattle, WA USA
Re: No Stats Display on New Tab Page
帖子 Jeffhere »
could there be an issue where the number of ads was too many digits for the resolution of the small laptop (1366x768), so maybe had an undesirable effect of blanking that ads blocked/data saved field?
There was a fairly high number of ads blocked...
Please take a screenshot
My test shows it's normal
Not sure if widescreen users have this issue
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
stats on but no stats appear
F12 view error
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
on newtab, pressed F12, locate to console, no errors...but warnings. see pic. Not sure where I should be checking, but this is what i snapped a pic of.
Please try backing up the user data directory and creating a brand new user data directory to see if it displays properly
Local testing shows that the function is displaying normally
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
deleting the user data dir....same exact thing. No ads info field....but I know I had that field at some point within the last month. I don't use "new tab" often enough.
I can't understand what's changed.
I was thinking it is field related vs screen resolution. I had millions of trackers/ads blocked, not sure on bandwidth or time saved fields. Maybe it overflowed. when you tested, did you have a 1366x768 screen and millions of ads blocked?
but then when I deleted the user data, I guess the ads blocked would reset to zero, unless stored elsewhere.
I tried to find a way to "reset total trackers/ads blocked but found no way to do so.
上次由 Jeffhere 在 2024年 9月 3日 09:41,总共编辑 1 次。
Jeffhere
来自: Seattle, WA USA
帖子 Jeffhere »
update: noticed on version 4.9.3 Kernel: 129.0.6668.48 all is now working. The shield is now displaying the ad stats properly.
I didn't have as many ads blocked on this laptop, but the shield data is large compared to the field name.
Allok now!
Allok now!
