Force Windows 10 as Windows version for people using older Windows
Windows 7 and Windows 8.1 are EOL-ed and Chrome started from Chrome 110 removed support for them.
My user agent string is like this:
Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/111.0.0.0 Safari/537.36
Some websites will refuse to load if Windows version is not Windows 10 or Windows 11 but Chrome version is >= 110. I suggest forcing Windows NT 10.0 for people using older Windows like me (I'm using Windows 8.1).
Re: Force Windows 10 as Windows version for people using older Windows
Thank you! But it won't modify the user agent version number. This is not what a normal browser does! Please use the user agent extension to solve this problem!
catsxp 写了: 2023年 3月 9日 23:46 Thank you! But it won't modify the user agent version number. This is not what a normal browser does! Please use the user agent extension to solve this problem!
OK. I forgot about extensions. It's very easy on Firefox based browser to do that globally via about:config as I recall.
Google ended up doing exactly what I suggested to you! This has been the case for some time now. Currently, I don't have to use any extensions to change the user agent, as everything is working out of the box for me.
jonathan7
帖子 jonathan7 »
First that is strange, you SELF use W8.1 but you want to force poeple tot Win10(+), except yourself? That is weird!
Second i hope that W7 and 8.1 are stil supported in the future by CatsXP.
And hope you will also do a Linux (DEB) and MacOSX version in the future.
