Bookmarks behind the field screen!
Lord Foxius
帖子 Lord Foxius »
Since version 4_6_1 and up to now bookmarks when there are many of them in several columns go beyond the screen border at any settings. It is impossible to use when there are a lot of bookmarks, some of them are simply not displayed. in 4.5.4, everything was fine. Please fix this.
And why is there only Chinese language in sniffer? Couldn't it at least be English so that everyone could use it?
*И на случай если понимаете по русский то без перевода.
Начиная с версии 4_6_1 и до сих пор закладки, когда их много в несколько столбцов, выходят за границу экрана при любых настройках. Пользоваться когда много закладок просто невозможно, часть их просто не отображается. в 4.5.4 все было нормально.
И почему в сниффере только китайский язык? Может хотя бы английский чтобы все могли пользоваться?
Re: Bookmarks behind the field screen!
Is this the case when opening multiple column menus? Can you take a screenshot?
Lord Foxius
帖子 Lord Foxius »
catsxp 写了: 2024年 6月 12日 20:11 Is this the case when opening multiple column menus? Can you take a screenshot?
Yes, exactly with multiple column menus. I made some screenshots when opening a subfolder in the bookmarks, part of the bookmarks are off the edge of the screen. I set different width settings to make it visible. but the size of the picture had to be reduced for the forum to accept it. 1650x1080 screen size.
