打开多个窗口时,关掉一个窗口,其他窗口也都会被关掉
嬴梓不吃姜
如题,打开多个窗口时,如果关掉一个窗口,其他窗口也都会被关掉。正常应该是之关掉当前窗口,不影响其他窗口才对
Re: 打开多个窗口时,关掉一个窗口,其他窗口也都会被关掉
新版有指针安全检测,目前这情况在关闭多窗口有概率会发生异常崩溃的情况!待google官方进一步完善!
This is exactly what I'm encountering. It's very annoying!
Note: It will trigger even if you don't have multiple windows opening. I added --incognito to StartupParm.txt so the browser will always start in the Incognito. Sometimes it will crash when you close the window (it's the only window opening!).
Open a new profile. Close the current profile. I use Close this profile button. The browser crashed. It's many hours since then. Check Task Manager. Found catsxp.exe processes still running and eating CPU. It's crazy!
LeeNic
yes, I also encountered the same problem!s6nonqxt9y886fdp 写了: 2024年 5月 11日 00:36This is exactly what I'm encountering. It's very annoying!
The problem is gone on 4.5.4
