Alter StartupParm.txt and the browser will not start
Well, I tried to enable --disable-dwm-composition, --disable-pwas-install, --disable-webtorrent-extension, --disable-windows10-custom-titlebar, and --disable-vertical-tabs. All of these features I don't use, and --disable-dwm-composition is recommended for Windows 7/8.1 users like me, as I recall. But the browser will refuse to start. I have to comment out each of them by trial and error to see which of them is causing the issue. But finally, I can't find what the problematic switches are. I ended up having to comment out all of them, so my StartupParm.txt is the same as what you shipped by default. Now the browser will launch again. The only thing that is safe to put in StartupParm.txt is --incognito. This is what I discovered.
Re: Alter StartupParm.txt and the browser will not start
Please update StartupParm.txt to include new switches and remove obsolete switches on each new release. Thank you.
Invalid parameters do not affect startup
Then what's going on? The browser refused to start until I roll back to the default settings.
