4.5.1 bug
4.5.1 bug
If you open both the incognito window and the normal window, closing the incognito window will also close the normal window and crash the browser.
Re: 4.5.1 bug
test ok!
try 4.5.2 bate-1?
Re: 4.5.1 bug
Well, I discovered that if I close the normal window then the incognito window will be closed as well and the browser will also crash.
Re: 4.5.1 bug
catsxp 写了: 2024年 5月 6日 15:31 test ok!
try 4.5.2 bate-1?
4.5.2 beta-1 seems to be OK.
Re: 4.5.1 bug
Update: No. 4.5.2 beta-1 still has this bug. If you open both the incognito window and the normal window, closing the normal window will also close the incognito window and crash the browser.
Re: 4.5.1 bug
Try 4.5.2-beta-2
Dump emails to:3303118@qq.com
Re: 4.5.1 bug
catsxp 写了: 2024年 5月 6日 21:22 Try 4.5.2-beta-2
I can't download. Your file hosting service refused to let me download. It's error 5002 and a bunch of Chinese characters that I don't understand.
Re: 4.5.1 bug
I downloaded 4.5.2 beta-3 and I also created and switched to a new catsxp profile. The problem seems to be gone.
Re: 4.5.1 bug
The problem is gone on 4.5.2 release.
