Black page
Black page
Occurs randomly. Most of the time, this happens when I leave a tab playing YouTube and browse other tabs. I opened multiple URLs in background tabs. When I browse one of these tabs, the problem occurs. Reloading the page doesn't help. There is no solution other than to close the annoying tab. If I open the very same URL in a new tab, then everything is normal. It has happened since kernel 124.
Re: Black page
New update: It doesn't need you to have one tab playing YouTube to trigger. It happens randomly. Most of the time, I experience this when browsing Reddit. You open Reddit threads in multiple tabs. It is very likely that some tabs will be black. This is on Catsxp 4.5.1.
Re: Black page
The problem is gone on 4.5.2 release.
Re: Black page
The problem is back on 4.5.4. The detailed setup: one tab playing YouTube, one tab browsing a page with embedded TikTok, and some links opened in background tabs. All of the pages opened in background tabs are black.
Re: Black page
Dark theme?
Re: Black page
catsxp 写了: 2024年 5月 22日 08:07Dark theme?
Yes. Dark them. Dark plugin on. Windows 8.1 64 bit.
Re: Black page
Dark theme!
That should be a normal situation
Some websites support dark themed color schemes
Re: Black page
catsxp 写了: 2024年 5月 23日 07:43 Dark theme!
I don't think so!
Screenshot for you to easier to see what the problem is:
As you can see the purple line, it's currently in incognito window.
Re: Black page
Update: It also triggers on the normal tab! When it triggered, I tried to turn off the Dark plugin on that site and reload, but it didn't change anything. You can only copy the URL, close the annoying tab, and then open this URL in a new tab. Xenforo forum posts with embedded TikTok almost always trigger this. I don't believe it has anything to do with the Dark plugin.
Re: Black page
Hi Mr. developer. You can't do anything with this or you don't care about me?
