Just noticed this possible issue when trying to print anything from Catsxp browser with version 4.1.4. Same issue with 4.1.1. Same with latest beta 4.1.5.
Using portable, 64 bit, running on W7 64 bit....
I can't print from the browser to my wireless printer or a PDF file. Printer queue says "0 documents pending" then disappears (as it normally would).
Tried printing from other programs and all prints OK.
I can also print the "self test" print from Windows....
AND when I downgrade to 3.12.5, all is printing fine.
Hope you can duplicate.
Possible Bug After Version 3.12.5
Re: Possible Bug After Version 3.12.5
Due to kernel upgrade, waiting for repair
Choose to see moreJeffhere 写了: 2024年 1月 20日 08:59 Just noticed this possible issue when trying to print anything from Catsxp browser with version 4.1.4. Same issue with 4.1.1. Same with latest beta 4.1.5.
You can select the printer you want to add
Jeffhere
- 来自: Seattle, WA USA
not trying to ADD printers, just trying to print from the web browser. As noted, I can not print. It goes through the process to print but nothing makes it to the print queue.
is that fixed now? Tested latest beta - it is NOT fixed, same issue.
上次由 Jeffhere 在 2024年 1月 23日 20:21,总共编辑 1 次。
Jeffhere
for better clarity: not trying to ADD printers, just trying to print from the web browser to pdf or my default inkjet printer.
It goes through the print process to print like it will work, but nothing makes it to the print queue.
try 4.1.6 beta-3
Jeffhere
Tried printing from browser to pdf and my inkjet and am happy to report all printed as it should.
4.1.6 beta-3 works properly. Thanks.
