Where is the built-in screenshot extension?
I recall it used to be installed by default. Nowadays I no longer see it anymore. I still remember when Catsxp still supporting translating via Baidu (which I think is more accurate than Google Translate). This is also no longer available
Re: Where is the built-in screenshot extension?
It has native screenshot function, so the built-in correlation is deleted
Baidu translation extension can be installed directly in Google Mall
Where is it? How to use it? I don't see anything suggests I could take screenshots out of the box. Currently I have to install and use GoFullPage extension.
- Rag
Another button only visible on normal window. I always use incognito window so I'm unable to see it. Thank you anyway.Rag 写了: 2023年 2月 17日 03:56Где это? Как это использовать? Я не вижу ничего, что предполагало бы, что я мог бы делать скриншоты из коробки![]()
