ver. 4.1.1 quits when using Vertical Tap
ttomomo
When choosing to use vertical tab, Catsxp just quits. (Ver 4.1.1 installed version).
Re: ver. 4.1.1 quits when using Vertical Tap
I have been using the vertical tab bar all along and there have been no abnormal situations. Please try to see if it crashes abnormally in a brand new user environment
ttomomo
I tried on a brand new portable version (ver 4.1.1), there is no problem using vertical tab. However if I use a custom theme, it quits when using vertical tap. Custom theme and vertical tab crashes each other.
上次由 ttomomo 在 2023年 12月 25日 14:03,总共编辑 1 次。
This situation is somewhat similar to the one encountered during the last kernel update
What is the theme used? I have tested downloading and installing theme extensions in the mall and found no abnormalities
ttomomo
'Slinky Elegant' from Chrome Web Store.
ttomomo
Are you using both the Slinky Elegant theme anf Vertical Tab at the same time?
4.1.2 beta-3 fixed!
ttomomo
Yes, 4.1.2 beta-3 fixed the problem of using both custom theme and vertical tab at the same time, but now the problem of quitting recurred if adding the line '--disable-direct-write' to the StartupParm.txt (similar to the problem in ver. 3.12.5)
The problem (can't use custom theme, disable direct-write and vertical tab all three at the same time) still needs further fixing. Thanks.
At the moment I don't use vertical tab and enabled Tab Scrolling flag for the horizontal tab.
4.1.2 beta-4 fixed!
