Use Google translate endpoint banned
Disable Use Google translate endpoint, and it works again.
Re: Use Google translate endpoint banned
Test normal!=
Please analyze whether packet capture is a network issue
catsxp 写了: 2023年 12月 12日 16:40 Test normal!=
It's very unlikely, as extensions still able to use Google Translate.
Please try clearing the cache
Old versions of JavaScript files can cause translation errors
2023-12-13 185909.jpg (10.8 KiB) 查看 67085 次
2023-12-13 185744.jpg (152.04 KiB) 查看 67085 次
After I upgraded to 3.12.3, Use Google translate endpoint worked again. Note: no clearing of cache helped, it only back working after I upgraded to 3.12.3.
Update: it only worked for a while, the issue has come back. Please help.
Update: Use Google translate endpoint is still broken on 3.12.4.
Close the node and use default parameters
I tested the function locally and found it to be normal
