Chrome Theme NTP wallpaper not visible
来自: Czech Republic
帖子 redfox »
When I install any of the Themes from Chrome Store, their NTP background images are not visible on new blank tabs, only the background color.
For example, install this theme https://chromewebstore.google.com/detai ... kaop?hl=cs.
Instead of cats, you will only see a pink background on NTP blank page.
Is this a Chromium limitation, or Catsxp?
Re: Chrome Theme NTP wallpaper not visible
catsxp://settings/newTab
close catsxp new tab
来自: Czech Republic
帖子 redfox »
I want to keep the blank new tab (not homepage with all the buttons), but with the background image from the theme.
Is it possible?
来自: Czech Republic
帖子 redfox »
I want to keep the clear new tab (not homepage with all the buttons), but with the background image from the theme.
Is it possible?
Please search for new tab extensions for related features
Function customization not supported!
来自: Czech Republic
帖子 redfox »
Thank you, I already made my own extension to complete this task. It even does not eat any resources.
