At me Windows 8.1, kernel 118 release is started instead of kernel version version 119. - 在我的 Windows 8.1 中,啟動核心 118 版本,
anonymoustly
帖子 anonymoustly »
Kernel 118 version says CatsXP is up to date.
Can you fix that???
在我的 Windows 8.1 中,啟動核心 118 版本,而不是核心版本 119。
核心 118 版本表示 CatsXP 是最新的。
你能解決這個問題嗎???
Re: At me Windows 8.1, kernel 118 release is started instead of kernel version version 119. - 在我的 Windows 8.1 中,啟動核心 118
Release?
m119 is Beta!
anonymoustly
帖子 anonymoustly »
Yes i mean the Beta, v3.11.1 Beta-3
It launched kernel 118 version. NOT 119.
I'm not sure what it do on W7, 10 or 11.
上次由 anonymoustly 在 2023年 10月 25日 19:19,总共编辑 2 次。
jonathan7
帖子 jonathan7 »
Thanks for helping me but at m119p9 the kernel 119 is working now, although the browser does not exactly start smoothly.
Mostly crash directly.
Dump file email to me
anonymoustly
帖子 anonymoustly »
not sure what you mean, but the final version working with no problem.
