v3.9.3-beta5 on Windows 8.1 - search on address bar on incognito window always crashed the browser
Today I decided to test a beta version that I always reluctant to do in the past. It turned out to be one of my most stupid decision. The quality of the catsxp browser has been reduced so much recently, that even released versions have so many regressions compared to past versions. Oh, maybe because I'm using an old Windows. Keeping the Chromium core working on older Windows is already an awesome work and I think I can't expect anything better. You have done the best you can. Thank you very much.
Btw, anyone on modern Windows encountered the same bug as me?
Re: v3.9.3-beta5 on Windows 8.1 - search on address bar on incognito window always crashed the browser
catsxp://settings/search
Private Window - Search engine used in the address bar
Please confirm if the relevant parameters have been configured correctly
The search engine on both normal window and incognito window is Google.
Or an abnormal crash?
Beta 6 released later in testing
If there are still exceptions, please send the exception dump file to 3303118@qq.com
Still on beta5 because I have not yet seen beta6. I confirmed that this is a crash. There is a dump file on User Data/CrashPad/reports.
Are there any startup parameters or flags enabled?
trying beta-7!
catsxp 写了: 2023年 9月 13日 19:29 Are there any startup parameters or flags enabled?
trying beta-7!
The only thing I have is Use Google translate endpoint. Btw, I sent you the dump file to your email. I will try beta-7 and report back.
Confirmed that the problem is gone on beta-7.
