Catsxp gone international?
I recall when I first knew and used the browser, there are still various signs to show it's a Chinese browser: Baidu and Sogou available as search engine, supports translation using Baidu service,... But nowadays, it's not any differences from other browsers developed by the West. Google as the default search engine, Baidu and Sogou are removed. Baidu translation service support is removed. I should be glad or upset about that? I don't know. I'm not Chinese. I only feel like I'm using just another mod of Chrome that I always used before I knew catsxp. The browser no longer feels special.
上次由 s6nonqxt9y886fdp 在 2023年 9月 15日 09:36,总共编辑 1 次。
Re: catsxp gone international?
Search is automatically configured by user language by default
Non Chinese users will not default to enabling Baidu or 360 search
catsxp 写了: 2023年 9月 13日 15:31 Search is automatically configured by user language by default
OK. I got it. Btw, how to setup Baidu translation service on catsxp? Baidu translate is more accurate than Google. It's awesome if there is something like Use Baidu translate endpoint on catsxp://flags just like Use Google translate endpoint.
The one you mentioned is actually an extension that can be installed directly in the app store
catsxp 写了: 2023年 9月 13日 16:17 The one you mentioned is actually an extension that can be installed directly in the app store
Please tell me which extension. A link to the Chrome web store is appreciated.
The extension has been removed from the app store...
Please try downloading from another source
0lly 写了: 2023年 9月 13日 19:05 https://www.crx4chrome.com/crx/128664/
Thank you!
Manual correction of Russian language pack~
This extension is not quite the same as what we used to have on catsxp. The extension is fully in Chinese that I don't understand anything and don't know how to use or customize it at all :(
p/s: Thank you anyway :D
