old theme craches in latest version of catsxp
alzcore397
帖子 alzcore397 »
with the latest version of catsxp
when i installed this old theme
https://chrome.google.com/webstore/deta ... hpbcdkakod
it crashes.can you check out plz?
alzcore397
Re: old theme craches in latest version of catsxp
帖子 alzcore397 »
can the administator tell me why the above theme is not installed anymore? the browser crashes when i click it to install it.thanks.
I'm not in front of the computer now. I'll test it tomorrow.
alzcore397 写了: 2023年 9月 10日 16:42 can the administator tell me why the above theme is not installed anymore? the browser crashes when i click it to install it.thanks.
Test OK!
0lly
帖子 0lly »
I have the same problem with different old themes in Windows 8.1.
For example with this one: https://chrome.google.com/webstore/deta ... deienflcoh
Windows 10 does not have this problem.
Apparently the problem is the compatibility of the 117 kernel and old Windows.
In old CatsXP 3.8.3 kernel 116 in Windows 8.1 everything works fine.
test ok!
3.9.6 beta-2 fixed!
alzcore397
帖子 alzcore397 »
thanks!!!!
