How to completely disable auto-update?
I'm using the portable version, which has auto-update disabled by default. The switch --disable-catsxp-update on StartupParm.txt is not honored.
Re: How to completely disable auto-update?
This is very annoying. Please fix it.
3.9.1 beta-7 fixed!
catsxp 写了: 2023年 8月 29日 20:393.9.1 beta-7 fixed!
I upgraded to the latest beta and now it's like this:
The problem is gone on beta-10. Thank you.
